API-653 Hydrotesting Required - bottom-shell weld repair
Under API-653, 12.3.1 When Hydrostatic Testing is required, then 12.3.1.2.e. It states "When removal and replacement of any part of the weld attaching the shell to the bottom or to the annular plate ring."
But then under 12.3.2 When hydrostatic Testing is Not Required. See 12.3.2.4.1.a. and b. gives examples of Shell to Bottom Shell Repairs that can be made without needing to hydrotest afterwards.
Which is it? Can we make shell to bottom weld repairs (in accordance to 12.3.2.4.1.a or b.) without having to hydrotest the tank afterwards?
We have 2 A.I.'s that have differing opinions.
jcneel
jcneel
RE: API-653 Hydrotesting Required - bottom-shell weld repair
Joe Tank
Thanks.
jcneel
Joe Tank
