Routing - Issues with Pipe Specification
I created some fittings to mimic slip fit plastic(PVC) fittings to use with the routing package. I am getting this strange problem. I start a route and I select Schedule 80 CPVC pipe. It then creates a section of pipe, Sch80 CPVC. OK.
Now, however, If I drag and drop a TEE, Sch80 CPVC, it creates two new pipe lengths and the problem is these new pipe lengths are Sch80 PVC instead of CPVC.
What do I need to look at in the fitting to make sure it keeps the base pipe configuration?
