PDMWorks check out list Info column External Ref ??
When I check out files in PDMWorks the Info column often shows External Reference on some files but they are greyed out, they are also checked.
What does External Ref mean in this case? and should I uncheck them?
Tom
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
RE: PDMWorks check out list Info column External Ref ??
I think the grayed out ones are the external files like Toolbox parts. You can't uncheck those.
I believe SW07 sent out in the box along with the CD's what each of the Icons mean in PDMWorks. That would be a good source for you to reference too.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
