PDF files not opening correctly with Viewers other than Adobe
Has anyone else had a problem with opening pdfs generated from SolidWorks with programs other than Adobe? We have Myriad and AutoVue here, and both have a major issue opening these pdfs, but Adobe is fine. AutoVue is set to be our systems main viewing software and markup utility.
Anyone else have an issue?
John
John
Certified SolidWork Professional
CAD will not make better designers; it will only make poor designers faster...
RE: PDF files not opening correctly with Viewers other than Adobe
Are you creating 3D PDFs? If so, it is possible that other viewers have issues with this.
regards,
Kevin Carpenter
CAD Systems Administrator
Invacare Corp.
John
