Creating a compontent pattern from a fill pattern?
Current situation:
I have a part with a cirular fill pattern, 3mm holes.
In these holes I want to place tubes. The first is allready shown.
SolidWorks won't let me use a feature driven component pattern (I get a message I can't use a fill pattern for my feature driven component pattern).
Besides mating each tube indepenently is there any other way? Tubes are to be of a different material.
The assembly:
The tube:
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer
RE: Creating a compontent pattern from a fill pattern?
How about creating a sketch in the part with the holes with only dots in the centers of each hole and then use sketch-driven pattern?
Bouke Brouwers
M-Des
The Netherlands.
The only thing that I can think of would to be make the tube part in the part level and make it a Separate body and use the same fill pattern command and place that component into your assembly.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
... or mate a tube in one hole of each circle of holes and then do a circular pattern of each tube?
... or create as a multi-body part and then Split and Save-as individual parts?
An ER for a Fill Pattern to be used as a feature driven component pattern would be good.
cheers
Bouke, creating the sketch points is quite a bit of work by itself, with 300+ points to go. I'd prefer a solution that is parametric as wel (as in, updates according to changes in the pattern).
Scott, that seems to be the best solution. I had thought of that as well, using weldments. disadvantage: manual updating of the BOM is needed.
Cor, the tube circular patterns could work, but it still is pretty labour intensive. The multibody & save as assembly method creates a part file for each seperate body, not able to use multiple instances of the same body in a newly created body. Quite stupid actually, since the weldment feature is able to recognize identical bodies.
I'll fill in an ER for both.
Stefan Hamminga
EngIT Solutions
Searching Eng-Tips forums
Just a quick thingy that came to mind.
The pattern you used to create the holes in the original part could probably also been done in the sketch lvl instead of making a feature pattern.
So, you could create a sketch containing only points of the entire pattern, which should be just as much work as creating the feature pattern of the holes. Then use that sketch for a sketch-pattern where you pattern the cut-extrude feature. That should add only 1 extra feature in your part which is not time-consuming.
Now in the assembly you've still got this sketch anyway to use to pattern the tube.
Then as result you would have your parametic solution right?
Bouke
Bouke Brouwers
M-Des
The Netherlands.
Unfortunately the Fill Pattern only works for features, not sketch entities.
cheers
