What test standards should be used for Radiator Testing?
I'm doing some research on automotive radiator testing. I need to find test standards for testing the complete assembly. I don't want to remove samples from the radiator.
I need a test standard for testing the hose fitting strength, and internal corrosion. I have ASTM B117 for external corrosion.
Also, I am planning on using the following:
SAE J1994 for Heat Transfer Performance (This will give   pressure flow vs. drop as well right?)
SAE J1542 Thermal Cycle Durability
SAE J1597 Pressure Cycle Durability
SAE J1598 Vibration Durability
Any suggestions would be greatly appreciated.
