sea water corrosion 316 vs 17-4
Looking for a little advice for gaining strength in a sea water (salt water) environment.
Presently using 316SS (no passivation) on a vertical post 1/2" diameter threaded in at the bottom with shoulder stop. Part is breaking above shoulder with large fillet applied. I know I need to at least passivate since I think corrosion is pitting away and weaking the part at stress points. I am also think to change to 17-4H1150 to increase yeild strength, but am a little concerned about corrosion and wanted to know if other options may be available. I believe toughness is an issue.
Part may be dry, wet or cycle between the two. Rod is being use to hold an oar assembly.
Thanks for you feedback and ideas.
Kind Regards,
MECOMAN
Kind Regards,
MECOMAN
RE: sea water corrosion 316 vs 17-4
Passivation will not give you meaningful improvement in corrosion resistance. 316 simply will not stand up in a seawater environment. But yes, it is good practice in order to make sure that you get all that you can from an alloy.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
I am still not sure if the failure was from corrosion or excessive load. The part does experience a large amount of repeated shock loading with a good bending moment.
Regarding passivation, I have seen none passivated thread corrode in 316 in 1-3 months and then apply passivation and get 3 years with part removed for other reasons/service.
How about the 17-4, added yeild strength should improve toughness, any thoughts on it?
Regarding the duplex 2205, how does it compare yield strength wise with 316 and 17-4 H1150?
Thanks Again,
MECOMAN
If you have parts with significant amounts of Fe int eh surface then passivation makes a huge difference. If a part is exposed to abrasion or wear then passivation doesn't really matter since you will be damaging the surface.
Your failures are probably some combination of corrosion and load. How much of each would take some work to figure out.
Rust never sleeps
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
You may get away with 2205, or even 2003, if you ensure
that the locus of failure has full exposure without a crevice. 2003 will pit, but it's a lot better than 316 and as strong as 2205. If 316 can last 3 years, then the added corrosion resistance of 2003, and moreso for 2205, should be a sufficient for a good engineeering solution, if not total immunity.
2205 will be the easiest to obtain if not the cheapest.
Michael McGuire
http://stainlesssteelforengineers.blogspot.com/
