V4 Ordinate Dimensioning
You can get Ordinate Dimensioning in Catia V4 using the option QUICKDIM (under DIMENS2). The first selected element will direct the orientation of the ordinate dimension.If the first selected element is a point, the dimension will measeue the closest end of the next elements.
