FAA Aerodynamic DER
FAA Aerodynamic DER
FAA Aerodynamic DER
Are there any FAA DER's delegated to sign off aerodynamic?  We have an FAA structures DER working on a B737 Upper wing surface repair, and need an aerodynamic signoff.
Any suggestions?
PhilLee
RE: FAA Aerodynamic DER
how about the FAA DER lists ?
FAA Order 8110.37D Chart G is what I think you need.
Then go to the FAA website and search the DER listing (a .pdf file unfortunately) for the person with the right delegation.
Chart G guys can find compliance for the testing side of things by the looks of it.  Is that what you are after?
