wall jib crane
wall jib crane
Hi
I have to design wall jib crane 5 Tonn arm 10 m and 8 m I use WF 500x300x11x15. I checked the stress, it's OK. but the deflection is to large about 120 mm. I dont have the relevant standard to be compare and I not sure that I can use L/150 for this case.
Pls give some standard such as CMAA, BS or FEM rule
RE: wall jib crane
You should be using relevant crane standards for this type of design work! If you don't have them, purchase them.
