Hi speed hi load bearing materials
Looking for some good suggestions for hydrodynamic bearing materials, such as stainless steel, cast iron. Rpms in the 7k range, loads possible to 10k plus/sq in.
Compatability with steel alloy shafting. And what about using DLC?
RE: Hi speed hi load bearing materials
Is there some reason you would not want to use Babbit?
You don't want to use stainless in bearings.
The only bearings that I recall that handle these loads are the tri-metal connecting rod type.  The are usually a steel backing with a layer of lead bronze and then a 0.001" face of babbit.
You could use CI as a backing, but it would need to be high strength.
The other surface is usually a nitrided or carborized steel.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
