electrical engineering
how to connect a 5" copper cadmium electrical line to a 5" copper magnesium line with 600 volts and 4000 amps running through it
RE: electrical engineering
With the power off..
We need more information if you want a viable answer.
Keith Cress
I'm assuming the connection will need to be insulated correct?  In what type of environment do these electrical lines exist (ie. Wet/dry, tempurature)?
Respectfully,
If it is broken, fix it.  If it isn't broken, I'll soon fix that.
Five inches. Bar,cable, round conductor? Is it the difference in material you are worried about?
Gunnar Englund
www.gke.org
