DC drive to AC drive retrofit
I have an application that requires retrofitting a DC motor and drive with an AC motor and drive. The application is the spindle of a CNC lathe. I have the nameplate data of the DC motor. KW 15/22 AMPS 78/118 FLD AMPS 9.7/2.4 VOLTS 220 RPM 1150/3450 I am looking for suggestions on how to calculate the size of the AC motor and drive that would be needed to replace the existing system. Any info or links on this subjest would be appreciated. Thanks
RE: DC drive to AC drive retrofit
