Eigenvalue Buckling Analysis Trivia Question
A thread in another forum brought up an interesting topic.
The upcoming AISC Stability Design Guide will put forth the idea of using eigenvalue buckling analysis capabilities of modern programs.
I think there's a very dangerous trap that's very easy to fall into and I'd like to throw it out there for discussion.
I'll illustrate the concept with an example:
10' long simply-supported steel column, 3" square cross-section. Pcr=pi^2*EI/L^2=134 kips.
Put this in SAP and it comes back with 134--no problem.
Now put this in SAP with a small bending moment. Still comes back with 134--maybe ok, maybe not.
Now put this in SAP with a 10000 kip-ft bending moment. It STILL comes back with 134--whoa!
The reason is that the eigenvalue problem is [Ke-lambda*Kg]{phi}={0} where Kg is the geometric stiffness matrix. It's filled with constants times P/L. It never sees the effect of the moment.
I'm not totally sure about this, but I think this type of analysis fails for ANY problem that has a nontrivial solution. In other words, put load on it and it deflects.
Opinions?
Opinions?
RE: Eigenvalue Buckling Analysis Trivia Question
Examples of frames for which I think this fails are:
Portal frames with one column longer than the other.
Unsymm single gable.
Pretty much anything that remains undeflected as load is applied, then all of a sudden, it bifurcates at a critical load.
Another example might be a symm portal frame with unif loads applied to the girders. This will cause bending in the columns and therefore a nontrivial solution. I think this one works fine as long as the loads are applied to the joints only.
It will also matter if the members are subdivided. Not sure if this works at all if column just go from floor to floor, for example.
I'm not totally sure about all this, so throwing it out there for discussion.
The new DG does focus on the DAM, but has sections on the Effective Length Method. They discuss eigenvalue buckling analysis for ELM and use it in some examples to get elastic buckling loads.
Later on, Chapter H stuff gets checked.
A page number in what? Draft Stability DG?
Example 5, Page Ex 5-9
Example 11, Page Ex 11-9, Line 352
Example 12, Page Ex 12-8, Line 281
It might work great for these cases. I'm just wondering if there are other cases for which the approach will be completely wrong, but non-obvious to engineers not intimately familiar with computational stability.
Perhaps I'm the one who doesn't understand it!
For one thing, I think they made their point--use the DAM to avoid all this garbage!!
What you were finding with SAP is the elastic critical buckling load which is only a part of frame stability, which also depends on the buckling mode chosen.
As you know, DM is the better way to go. This is according to the authors of the stability guide and from what I understand, AISC will be adopting this as the preferred method in the future.
I don't think I would mess with trying to get these old story buckling "K" equations to work with software when there is DM, I am SURE there are some situations where the ELM story equations don't really fit. Just like ELM in general; and the stability guide authors and AISC realize this. All of this "K" stuff can get really confusing...
If you really want to investigate frame stability, there is a program called MASTAN which looks very simple but is actually quite advanced in terms of investigating frame behavior and allows you to look into different analysis techniques. It is free to download, but unfortunately I can't find the link right now.
http://www
I agree that Appendix 7 is the way to go, especially for any problem with non-obvious K calcs.
Still not sure that the derivation of K through the use of modern programs' buckling analyses is a good idea for many engineers, though. It is more of a trivia question, I suppose, because most people won't try to do that anyway.
Your mention of MASTAN which I'm not familiar with made me think of MYSTRAN authored by Dr. Bill Case a member of the team that developed NASTRAN. The home page has an illustration of a truss eigenvalue problem.
http://www.mystran.com/index.htm
-Mike
Wow, things have really changed.
I'm not sure I know what an eigenvalue is anymore, let alone check one by hand.
-Mike
My problem with eigenvalue buckling analysis stems from my opinion that almost no design engineer will be able to spot subtle modeling problems that might cause huge errors. I think it would've been better left un-said in the DG. If somebody knows enough to go looking for it, then fine--they probably have a background in this stuff.
