Offset of non-planar curve
Gents,
i'd like to offset non-planar curve (spline for routing),
i used Offset curve from right-Menu,i picked my curve, then Face(s)on which to offset (i picked Ref-Plane),but nothing happend :(
Some usefull i-deas??for any, thanks
cad - designer
i-deas 11nx  sworks 2006   ug nx 4.0.0.25
IMB InteliStation M Pro
RE: Offset of non-planar curve
I am not certain how the command "Offset" will prompt for faces to offset to. Maybe you mean the command "Project" instead?
The "Offset" command does not consider offsetting planes, as it offsets in 3D. What should the end result curve be? (2D curve that is on a ref plane or 3D curve in space?)
If you can share the step by step of which command is used, and what I-deas prompts for during each step of that command, we may be able to offer more suggestions.
Mike Hsieh
Siemens Automation and Drives
Mike Hsieh
UGS
