How do I point FlexLM to correct NIC
I'm attempting to install FlexLM on my workstation. I have a (legitimate!) license file but when I install the license server (old build WF2, M171) it sees the wrong NIC's MAC address.
I have logged a call w/ PTC (call # 5739941) but have not heard from them yet. The knowledge base at PTC wasn't much help, tho it did report a situation on a HP machine w/the NForce network controller - TPI 131483. The TPI prompted me to check the registry on my computer and the NIC card that has the MAC address in my license file does have a registry entry in the location specified by TPI 131483.
When I run ipconfig /all from the command line the report shows the Physical Address (MAC) for both the ethernet NICs that are in the box.
If I disable the one NIC (3Com on MoBo) Flex will use the one that is in the License file (Netgear wireless).
I would like to not have to dissable the one NIC to get Flex to see the correcct NIC. Does anyone know how to do this? (I am downloading the disc images for latest build of WF3 so maybe FlexNET is smarter - but I'm not holding my breath!)
Thanks!
Thanks!
RE: How do I point FlexLM to correct NIC
PTC has a program that will return the address that Flex will see.
Ben Loosli
Sr IS Technologist
L-3 Communications
See thread554-108718: Wireless network cards and Pro/E license for the solution that worked.
Now to see if I can make one installation with a list of different license servers (mine first then clients' 2nd and 3rd) so that I can fire up the programs if I have the USB device attached or an active VPN to either client!
I may have to work up some script files that copy the various batch files that contain license server information (proe.psf, proi.bat, ptcstatus.bat, etc) so that depending on whether I want to use a clients license while attached to their VPN or my own. I would launch IntraLink & Pro/e from a shortcut that would copy the appropriately configured files into the launch_point/bin directory. Though a little complicated, I am currently using script files to configure start parts and drawing formats and such already, depending on whom I am working for at the time.
Thanks again for the replies!
Have a great week,
Tom
