PC Power supply
PC Power supply
Does anyone have much experience with pc power supplies? Is there any reason that using a 12V power supply from a desktop will not work to power a car stereo that is pushing two 130 watt max speakers? Will the power supply produce enough continuous current?
RE: PC Power supply
By the way, can your stereo actually put out 130W/channel, or is that what the speakers are rated at? It wasn't clear from your description.
RE: PC Power supply
RE: PC Power supply
pc supplies are not intended to withstand for extreme current requirements like a bass sound, so would oscilate or shut down, even damage if subs are connected. be careful.
regards
killa
RE: PC Power supply
I don't think I've ever seen one that DIDN't state what its outputs were limited to on the label.
Keith Cress
RE: PC Power supply
RE: PC Power supply
RE: PC Power supply
h
TTFN
RE: PC Power supply
What's with all the bad information? Good modern PC power supplies are strong. Last year I put one in a laboratory instrument driving a 12 V, 0.5 ohm heater controlled by an audio-frequency PWM. It didn't break a sweat, and saved loads of money over a "proper" supply. As an example, the Enermax EG851AX-VH(W) can put out 28 amps on its puniest 12 volt rail. Depending on its internal construction, you might be able to parallel the 12 volt outputs to get 38 amps total.
"switched power supplies like a pc one, will produce much noise in the audio band, because of the current switching."
The modern ones switch way above the audio band. If noise turns out to be a problem, a choke and capacitor should take care of it.
"PC power supplies typically will output a lot of power on their 3.3V and 5v outputs, but the 12v outputs is a lot less as there are not that many things that use 12v in a PC."
On modern supplies the 12 V rail is by far the stoutest. It's just not practical to run a pair of 130 W processors on 3.3 V: the needed wires are too thick. The processors, video, and motors all run on 12 V, and often the memory and chipset do too.
"pc supplies are not intended to withstand for extreme current requirements like a bass sound,"
They most certainly are. Consider a game that has 50% utilization with a 100 Hz frame rate, running on a pair of 100 W CPUs and a pair of 50 W video cards. The PS would easily see a 100 Hz, 250 W square wave load on its 12 V rail.
"60 watts at 12 Volts equals 21 Amps, much more than any PC power supply will supply (more like one Amp at 12 V)."
If you have money to burn and reliability isn't a worry, there are units that go up to 72 A.
RE: PC Power supply
20A @ 5V
24A @ 3.3V
0.8A @ -12V
and
42A @ 12V
http://www.antec.com/specs/NeoHE550_spe.html
Keith Cress
RE: PC Power supply
RE: PC Power supply
RE: PC Power supply
I bet your older supplies had NO 3.3V either. I was resurprized when I looked mine up.
My video card spec states that it "needs a minimum of 28A @ 12V"
This is why a functional "Suspend" is absolutely vital, as leaving a PC with a high-end video card running all day will put the "hurt" on you.
Keith Cress
