VIEW SCALE
VIEW SCALE
Can I give different scales to parent & children views?
RE: VIEW SCALE
yes, --> properties
RE: VIEW SCALE
RE: VIEW SCALE
you should have been more precise then.
- Select the SectionView
--> within the RibbonBar
-- set the PullDown 'Scale' to the one desired
Works for 'regular' views as well
dy
RE: VIEW SCALE
RE: VIEW SCALE
no need to scream ... you're runing V18, right? then
it's not possible to have adiffent scale for the section
Upgrade to V19
dy
RE: VIEW SCALE
for I always have the section views without alignment it did work
and so it does in V18 too:
select the SectionView --> RMB and deactivate 'Maintain Alignment'
then you will be able to change the scale
dy
RE: VIEW SCALE
Thanks Don for helpful tip. It works fine when deactivate alignment.
I have only V19, no older version.
