Temperature un thermoforming
I'm trying to optimize the thermoforming department in the factory where I'm working. I need to choose at which temperature the oven as to be set and how long we have to put the plastic in. I'm wondering if there's a formula or a easy way to found the temperature inside the plastic sheet upon the time if the temperature in the oven is stable and the plastic specification are none?
Alex
Alex
RE: Temperature un thermoforming
The temperature will depend on the polymer type.
The supplier of the plastic sheet should be able to specify a maximum temperature.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
