Simulink w/ Code CCS Real-Time Workship External Simulation Error
When I try to run my Simulink model in external mode so I can monitor the dataflow, the real-time workshop gives the following error:
Could not execute target data map file 'pld_c6000_rtw\pld_targ_data_map' or it does not exist.
Stop the target, delete the pld executable, rebuild the code, and try again. Note that execution of external mode requires the build directory to be present.
I have checked the folder and it does not contain this file, and does not seem to be created when I build the project.  I am using the Embedded Target for TI C6000 and a C6713 DSK.  The model executes fine when compiled to CCS and run.  I have read all of TIs literature and have not had any success.  If you have any suggestions, please let me know.
Louis S.
