Catia to Solidworks help
Im designing a fixture for a part that came as a Catia file.
I imported it into solidworks, but can't find the tooling points on the model. I can see them on the drawing, so I know they are in the Catia file, but did I lose them going to solidworks?
RE: Catia to Solidworks help
Unless they were an actual feature in the model, I doubt they would be in the parasolid.
Could they have been added to the drawing only?
Am I going to have to ask my manager to ask our contact for a different format, or is there another application I can use to get this data? Is it possible to use another app to open it and then export it as a format that solidworks will read point data from? If I end up asking for another format, which should I ask for?
I know its a lot of newbish questions, but any help is appreciated :D
As for which format is best, it depends on the software the model was created in. Parasolid is usually the best.
In regards to the parasolid format, solidworks help told me it would not import point data from a x_t file. The origonal model was a Catia file, but they did not see fit to send us this model.
Your responses are appreciated.
http://cadlink.libresite.com/Default.aspx?tabid=87
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
