Computer turns off without warning
Help...!
I have the following hardware:
650W power supply (spire 650w)
AMD Athlon-64 X2 5000 AM2 Box
4gb DDR2 PC6400 memory
WD SATA Raptor 74GB 10.000rpm
ATI Fire GL V7200 256 MB PCI3 Card (driver 6.14.10.6392)
Mobo ASUS M2N-SLI deluxe (we had MSI K9N platinum, we changed but it did not matter it seems)
19gb swap (d:\)
Software:
Windows XP Prof. 64bit UK
Solidworks 2007 sp2.2 32bit (we lost the 64bit dvd :(, but it should not be a problem according to the solidworks resellers)
Problem:
The computer shuts down without warning and is not restarting when solidworks is running idle or when i use it. Our electrical installation is ok. The processor is running idle. This happens a few times per day.
I really dont know whats wrong :(
pls help me.
19gb swap (d:\)
Software:
Problem:
pls help me.
RE: Computer turns off without warning
But based on what you've done and are describing it sounds like it's hardware related.
That's the quick off the top of my head thoughts, if I think of anything more I'll post back.
Kevin Carpenter
CAD Systems Administrator
Invacare Corp.
Make sure that the power opptions are set to standby never, and hibernation never.
1) Windows 64-bit--probably a driver/hardware conflict issue
2) A few years ago I was getting restarts and freezes in my old system, particularly after the monitor shut off while I was away (after screen saver timed out). The issue turned out to be a bad motherboard (yes, it was new and had this fault since the computer was new). Once that was replaced, the problem evaporated. It took a bit of trouble-shooting with tech support to isolate the problem to the motherboard.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
What are you're fan speeds in the bios?
hidde
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer
If you can switch out the power supply with one like it and see if that fixes the problem.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
hidde
In any case glad to see you're stable once again.
Kevin Carpenter
Invacare Corp.
RFUS
Jeff Mowry
It turnes off most of the time when i use solidworks, but the last time it turned off when it was processing my login.
