Pipe Size for thermowell installation
Is there a minimum pipe size needed for a thermowell installation?  I have seen some example installations where pipe 3" and below is increased to 4" for a short length specifically for the thermowell.
any Ideas?
thanks
Mark
RE: Pipe Size for thermowell installation
The shortest common well length is 2.5-inches.  Thus, small pipe is often enlarged to 4 NPS.  Other techniques include elbow insertion.
That is why I love elbow-lets.  If increasing to 4" NPS is inpractical, see if the engineer will let you use one of these instead.  This way your probe won't hit the other side of the end wall.
http://www.ht6.cn/outlets_elbow.htm
Zuccus
or 45 degree insertions.
Hi, I'm a pipingdraftsman from Europe and worked for a company called Dow Chemical.
They had a presentation about thermowells in 2003,
where they found a supplier who delivered small wells.
Even in a 1" line you didn't have to enlarge the size.
Can someone tell me what supplier(s) have tese wells?
Greetings.
Most suppliers carry smaller thermowells, what you need to worry about is the instrument that goes in it.  You need to check with the people who are spec'ing out the instruements.
Zuccus
Thanks a lot, what difference is there in a couple from 3mm
diameter?, temp.ranges can be specified
