Hot to increase/decrease distance
Bentley:Microstation:2D Drawing
How can I set the distance from the object to the Dimension Extension line (normally a few mm)?
RE: Hot to increase/decrease distance
Cursor,
Which version are you using? This will help alot because each version is different.
Namdac
Hello Namdac
Thank you for taking the time to reply to my post.
According to the help abput I am using version. 8.05.01.25 (V8 2004).
Cursor,
First click on the dimensioning tool, the element dimensioning tool box opens. Next to the word style you will see a magnifying glass, click on it and the dimension styles dialog box opens, Click on extention lines. This will allow you to set the offset.
Namdac
