Corrosion by High Temp Steam
I understand in the boiler industry that steam is corrosive, and corrosivity increases with steam temperature. Is there any data showing how steam corrosion increases with temperature (and possibly pressure). Up to 1300 C
RE: Corrosion by High Temp Steam
Considering that many power plant boilers will run for 30 years with minimal repair show that with good design, water control, alloy selection, and maint practices you can handle the application.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
http://
