Create an angle plate between two tubes
I have some tube welded together, I succeed to create these tubes as a solid model but now I have to add some angle plate or gusset between them.
These plates are really important in these high stress areas. But it's seems quite difficult to create them. I could add them as a solid model, or maybe just had some contact constraints between the tubes in the plate area.
Have you some ideas to solve this problem, or tips to create the solid model?
Thanks for all,
Best Regards,
Mickaël
Thanks for all,
Best Regards,
Mickaël
RE: Create an angle plate between two tubes
My first guess, one should be able to solve the problem using the boolean operation as VADD.
Alex
Thank you,
Mickaël
Alex
Mickaël
