Full round blend
Full round blend
Does anybody know How I can gice full round blend between 3 faces?
RE: Full round blend
this way?
Corner_rnd V19
All 3 edges selected and then the radius is applied
dy
the outcome will be the same, I think. It will work
with 3 faces as well. There are, however, 2 steps more
for you can only select 2 faces.
dy
the number of steps is only one more (it was due to my selection)
Blend/Radius (V18)
dy
it *may* not work on your model because of the faces you
try to blend. In my example they are straight and plain
dy
Imagine a trangular stiffening web on a casting. If the web then has a draft angle applied to the side faces the top face will vary in width. What you now need to do is completely remove the flat top face by applying a varying radius fillet that is tangential to both side faces and the top face - as the pattern maker may do with his sand paper.
As far as I know this is not possible with the fillet command - unless it's been added as an option in V19 (or V20?).
It is something that is in Catia and also, I think, Solid Works.
Try using a variable radius fillet and adjusting the radii.
I just tried creating a blue surf and using the replace face command but couldn't get it to work.
bc
Thanks.
I think, this is a good reply to clear my doubts, but not complete solution for we both, right?
picture would have been an advantage -- no guessing
needed
dy
You could try building the feature as surfaces, then uniting them with your solid body.
perhaps someone should submit an enhancement request.
bc
How I can attach picture to postings?
http://www.eng-tips.com/faqs.cfm?fid=1100
