GT 9FA DLNII TK fans issue
On site we have a Gas Turbine GE 9FA DLNII. The exhasut frame of thegas turbine is cooled with inlet of air via the TK fans, exhasut frame blowers TK-1 and TK-2. What we have seens until now is the motors working to nominal current, the diverter flap stucking in the middle position. These fans take air form the machine hall and blow this air to the exhasut frame of GT. I want to ask if there is relation between the temperature and the pressure of the air in the machine hall, where these blowers suck the air and the motor current consumption.
RE: GT 9FA DLNII TK fans issue
What is the pressure in the machine hall?
With respect to temperature, the hotter the air, the less dense it is and the fan amps will fall off because it is moving less air.
Conversely, the colder the air is, the more dense it is and the fan for the same speed and damper setting is 'pumping' more air and it takes more power to do so so the fan amps go up.
rmw
