measure a curved line?
How do I get to know the length of a curved line in CAD?
RE: measure a curved line?
Won't list give you the length when
you select it?
I don't know what a curved line is, but "_list" is right.
Or use the command "_lengthen"
Or look in the properties window (Since AC2000)
Or...to be continued...
Lothar
ADT 2004
No I mean a spline, by curved line. Properties nor lengthen works.
try the area command
On my machine, Exxit's first 2 suggestions also give the length of a spline, "list" and "lengthen".  The Lengthn command doesn't work on the spline but it does give the length.
