immersed object
immersed object
I have successfully used urethane materials to pot electrical items subjected to vibration but now have a new problem, items that are immersed in oil. The parts are simple in design and everyone who has come by with their 2 cents has said that the oil will dampen the vibration, but I need to analyze this. The parts are high voltage in nature so bracing (ie making a nice short to ground) may not be a good option in initial design or as an add on later-I need to make them stiff enough upfront. All of my texts apparently assume that the parts are shaking in air and I have not found any literature to guide me here. The amount of air displaced in these cases is pretty low, but the resistance to moving the oil out of the way will likely be pretty high in comparison. Does any one have any references that will help me with this?
Bob
Bob
RE: immersed object
RE: immersed object
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
RE: immersed object
My suspicion is extra features like blades or close fitting stationary surfaces would have to be added to the components to pump enough oil to provide significant damping for small amplitude forced vibration control.
RE: immersed object
as GregLocock says, it's a very complex matter. Theoretically, each mode of vibration could be categorized (out-of-plane bending, for example), and depending on the order of the mode one could find equations which would lead to the "reduction factor" defined as the ratio between the natural frequency value "in air" and the natural frequency value "immersed in the medium", taking into account densities, viscosities, etc. A forced vibration analysis could then be done with the mode superposition method.
I said "theoretically" because this can become extremely involved: these factors can be calculated, as far as I know, only for very simple modes and for very simple shapes (pure-beam, pure-membrane,...).
What has been said here, that the reduction depends upon the participant mass of fluid, is totally true, so the idea of maximizing this mass, independently from knowing exactly which it is, is very good I think.
As a last resort, you could do (if you have the software), or have it done by a third-party, a FE vibration analysis using "fluid" elements surrounding the body of interest.
