HP1050C questions
HP1050C questions
HP1050C questions
THe specs for this printer says it is "dual paths for roll and sheets". Do you have to unload the roll (example 11") then load the sheets manually (example 24")? I know it does not automaticly switch, but was not sure what this meant. Can sheets be loaded w/o unloading rolls? It looks like the only dual roll plotter that automaticly switches is the hp4500. Does anyone have any other recommendations for dual roll plotters? thanks
RE: HP1050C questions
Ask your dealer.
Mike Halloran
Pembroke Pines, FL, USA
