how to change from mm to inches
Currently using INVENTOR 10.
I created an entire assembly of components in the wrong units (should have been inches, created in millimeters).  Aside from modifying every component sketch and feature to the correct size, is there an easy way to change the components/assembly?  Is there a function similar to the SCALE command used in AutoCAD?
RE: how to change from mm to inches
You can derive the parts and scale them.
David
