What Pillow Bearings To Use On A Rotary Table (Vertical Shaft)
I'm currently designing a rotary table (light application);
I would like to know what type of "Pillow Block Bearing" I can use to mount the rotary table?
Any response will be greatly appreciated!
RE: What Pillow Bearings To Use On A Rotary Table (Vertical Shaft)
If accuracy is important, no mounted bearing is good. There is some clearance between the housing and outer race. If some movement is acceptable piloted flange bearing or 4 bolt flange bearings with stops welded on the sides will be the most rigid.
