Stability
Stability
Stability
I am trying to determine what is meant by "coefficient of structural stability" and "coefficient of structural resistance".  What are acceptable values for these?
RE: Stability
Are these quotes from a particular reference?  Some context is needed...
If you "heard" it on the internet, it's guilty until proven innocent. - DCS
RE: Stability
They are outputs from an Algor structural analysis software.
RE: Stability
The Coefficient of Structural Stability sounds like the ratio of nonlinear deflection to linear deflection, but there's no way to be sure without digging through your software manual.
RE: Stability
I don't have a manual.
RE: Stability
Unless somebody here answers, my only other idea is to call tech support.  Gotta figure it out somehow.
RE: Stability
I didn't know Al Gore wrote software. Just kidding!
RE: Stability
Algor could not help.
RE: Stability
Hmm, lets see, you are running a FE code with no manual and the vendor can't answer a simple question about what their code outputs.  Sounds like you need to purchase a different code with documentation and support.
