run an analysis with a C/C++ user subroutine
Dear all
I want run an abaqus simulation with a user subroutine written in C/C++.
I have downloaded one from abaqus online support system answer 737.
I modified my extension file from .c to .cpp. I add it to a Win32 empty project in Ms Development Environment 2003.For fixing a link warning , I modified in visco.cpp properties pages, debug information format=disabled.
I compiled it successfully.
In abaqus environment file, for fixing some link warning otherwise occuring during my abaqus execution, I add in link_sl parameter: '/nodefault:libcmtd.lib','/noentry'.
Here what I get trying to run my analysis
C:\Documents and Settings\alorenzom\Documenti\HC3FEM\AbaqusUSrI>abaqus -j visco_
dload -user visco.obj interactive
Old job files exist. Overwrite? (y/n): y
ABAQUS JOB visco_dload
ABAQUS Version 6.6-1
Begin Linking ABAQUS/Standard User Subroutines
5/29/2007 11:32:42 PM
Creating library standardU.lib and object standardU.exp
End Linking ABAQUS/Standard User Subroutines
Begin Analysis Input File Processor
Run pre.exe
ABAQUS License Manager checked out the following licenses:
ABAQUS/Standard checked out 5 tokens.
<13 out of 18 licenses remain available>.
5/29/2007 11:32:43 PM
End Analysis Input File Processor
Begin ABAQUS/Standard Analysis
Run standard.exe
5/29/2007 11:32:44 PM
ABAQUS Error: ABAQUS/Standard Analysis exited with an error - Please see the
message file for possible error messages if the file exists.
ABAQUS/Analysis exited with errors
and in msg file I find 'error user subroutine dload missing'
If it could be useful:I work on windows/x86-32.I have installed ms platform sdk 2003,Ms Visual Studio .net 2003,intel fortran compiler9.1.I run an abaqus analysis with a fortran user subroutine successfully.
Has any one got any suggestions for me?It would be very usefule for my work.
Thanks a lot in advance for your helpfullness.
RE: run an analysis with a C/C++ user subroutine
Is any specific reason for which you want to complicate your life and not write the subroutine file in FORTRAN ?
Yes he is my chief!
By the way, I just slightly modified my subroutine source code and I run my simulation successfully. I compare successfully some results in odb obtained from my simulation and those corresponding in odb obtained from simulation with fortarn user subroutine (that I downloaded from abaqus online support system answer 737 too).
All's well that ends well.
Bravo!
Grazie! ma questo รจ un forum inglese!!
Con piacere.
Dear 94710,
I want to ask you if with the fortran subroutine you can run several analysis changing change some parameters. How does it works?
thanks,
Albert
Do you want to run with a single execution procedure more than one abaqus analysis jobs that are different only for some parameters, don't you?
Sorry I don't know how you can do this and if you could use fortran subroutine to do this.
I'm performing a study of convergence of a solution through mesh-refinement and I'm using a c++ code to generate all my input files and an ASI (abaqus scripting interface) script to run all related jobs.
Or perhaps you want to define a fortran subroutine with a parameter that you set in your input file?
By the way try to give more details about what you want to do so I or anyone can help you.
Hi 94710,
What I am trying to do is simulate the propagation of a crack. I am taking a quarter of a plate and release the node changing the simmetry condition all the time. With fortran I modify the input file changing just the symmetry condition. then I run the simulation again with another symmetry condition and so on.
What I would like to do is to release some node from the symmetry (in order to simulate the crack growing) read the results from the *.dat file and the start again.
I saw your post and I was wondering if there is any fortran subroutine already implemented.
Albert
Sorry I'm not able to help you about this.I have no experience about this.I hope someone can help you.Post a message with appropriate title and briefly all of your information.Good Luck!
Hello all,
I came across your mails while looking for the possibility of running ABAQUS solver for the parametric studies. And I would like to ask whether we aim the same, or not:
1- After creating a model in ABAQUS user interface, an .inp file is created.
2- This .inp file may be re-written with some variables which could be assigned by some programs such as fortran, MATLAB (my choice).
3- Then calling ABAQUS solver without using user interface and  repeating the runs for any time the value of the variable is changed.
Am I wright in my expressions above?
If yes, let's seek the answer together.
Ahmet Anil Dindar
1. Yes, if by ABAQUS user interface you are referring to ABAQUS/CAE.
2. The inp. file is a text file describing the FE model using rules and keywords and can be (re-)written by an external program. In fact many people do not use ABAQUS/CAE and prefer to create the .inp file directly.
3. You can submit the .inp to the solver via command prompt, and yes, you can write a program to do that in a loop and to alter the .inp file during each iteration.
