wire 3 wire prox as 2 wire
I know I have done it before, but I'm drawing a blank now. How can I make a 3 wire prox (solid state magnetic switch) act as a 2 wire one?
RE: wire 3 wire prox as 2 wire
Clear a reed switch is a magnetic proximity detector and only needs two wires.
Presumably what you did before was something like connect the output to ground, giving you two wires: the supply wire and the ground wire. Then you applied current from a current source, or a resistor, and detected the change in voltage at the power source end of the cable.
