Suggest contact name for F-15 if any.
Hello Wil,
Since I need to keep supporting information in my files. Can you suggest any contact name from the F-15 Eagle manufacturing plant who can actually confirm that this part number is actually used in one of their airplanes. Any contact name(s) suggested will be greatly appreciated. Since this type of plane is also of military use I don't know how confidential they can keep this information. Any other advise is welcome too.
Thank you very much in advance.
Miguel.
Miguel.
RE: Suggest contact name for F-15 if any.
TTFN
Sorry... You need to develop Your own contacts with the F-15 crowd.... mine are both confidential and "old".
NOTE: the F-15 has severe data restrictions due to both I.T.A.R.s and Boeing proprietary data rights. If You have a legitimate need for the written data, then it should not be a problem acquiring the data... otherwise you will be locked-out.
Regards, Wil Taylor
Some time ago I was doing a crash saftey analysis for the seat rails on a 747-200C Freighter....no such luck. I had to sift through 500 pages of the original analysis work to get loads and resultants.
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
