units precision
units precision
units precision
Hi I´m having problems to set the units precisions.
I wan´t to change it so I´ll get the precision to 0.123456
now I only have 0.12.
Is it possible to change this so I dont have to open the fileproperty every time I open a new template??
Please help me.
I´m using Solid Edge v19 sp5.
Many thanks ahead yours sincerly Jan Lindén
RE: units precision
Jan,
then File --> Open your *template* and change the precision then
save it.
BTW: this will only affect the displayed precision internally
ist will always be double precision. If you are metric
.12 is sufficient and should only be changed for some
dimensions where it deemd neccessary.
For angles I fount out to reset it from 1 to .12 otherwise
an angle of 44.98 will show as 45 which caused me some headaches in one case ...
dy
