Premium License Accessibility
We have two users with SW premium installed. We have one SW premium license. Is it a "first come first serve" for this license? It would make sense to me that unless you have activated an add-in that calls for a premium license it should be accessible to both users because now if I want to use routing I have to start SW before the other user.???
Can this be changed?
RE: Premium License Accessibility
It is illegal to run a single licence concurrently on separate machines.
If you only have one license, then CBL's emphatic "Yes" is true. If you have two licensing, and you just want to be certain of which one you are checking out...different story.
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
Lower Alabama SolidWorks Users Group
Magnitude The Finite Element Analysis Magazine for the Engineering Community
Kevin Carpenter
CAD Systems Administrator
Invacare Corp.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
So, if you have three licenses, two of them Premium, one Professional, and you installed Premium on all three workstations, the first two users who log in will get the Premium, the third will get Professional.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
