Screw compressor oil temperature?
I have a small Paletek 10 hp oil flooded screw compressor, and it seems to run hot oil temperature. If the ambiant is 90 degrees F the oil can be 200 or 210 F.
Is this excessive? What is the danger temperature?
Thanks!
gr
Thanks!
gr
RE: Screw compressor oil temperature?
David
Your unit should have a high temperature shutdown switch that is set from 235 to 245 degF.
What is 100F above ambient based on? What inlet temp, what suction pressure, what gas, what oil inlet temp, what bullet in the oil-cooler bypass valve, what oil flow rate?
If you are assuming atmospheric air, then at what elevation? At sea level, the machine would be doing 7.8 ratios. At 5,300 ft it is doing 9.3 ratios. If the oil were not present then the gas would have gotten to 1.8 and 1.9 times inlet temp (in absolute units) respectively which is a 65F temp difference if you started at 90F.
For a specific machine and a specific suction and discharge pressure I can calculate the BTU's added by heat of compression for a given gas-inlet temp. I can calculate the rate of heat transfer to the oil based on some pretty gross assumptions about the portion of oil that is going to the bearings vs. the injection oil (if there is a constant-speed oil pump, if the pump speed is based on driver speed or if there is no pump then this is rougher). But knowing what portion of the oil is even going to the cooler is really a crap shoot.
The rule of thumb that I've used is that you get something like 35F oil temp rise for 10 ratios, but I've seen that number as low as 15F and as high as 60F.
I don't mean to pick on you, but that number doesn't make sense to me. Sorry.
David
A 10 hp Palatek is a single stage screw compressor
Initially that does seem a little high to me. But what has the oil temp been historically? Has the machine been in service long? Is it installed in a dirty environment? Are the coolers clean? Is the thermostat working? Is the inlet filter clean? Are the inlet passages to the canopy blocked? Is the oil level ok?
I combat overheating air compressors on a daily basis. I agree with crjones. I would expect to see an 80 to 100 degree F increase in oil temp over ambient.
***The hotter the room temp the higher it goes! 190 to 210 if all is well is type, but in higher temps it wants to go higher and sometimes the safety kicks the power off.
*** about 2 - 3 years
*** No, but is is a small room with a dryer and a backup piston compressor, so heat builds up. There is a fan driven 16" inlet of outside air and fan driven outlet so air flow is pretty good (but not enough!). The only way we keep the Palatek oil cool is to enclose the heat output of it and duct it out, and have a large diam pipe on the inlet and direct that directly at the Paletek.
*** Yes, cleaned often
*** Not sure, not sure it has one!
***** Something I haven't checked myself, but I think so,
***Hmmmm.... what's a canopy on a compressor?
*** Yes
*** One problem is that the incoming air ducts go through another boiler room and pick up 10 degree extra on the way in.
gr
Also the temperature rise is based on the inlet air and cooling air being the same. If the air going into the cooler is too hot the oil going back to the air end will be too hot and then the discharge temperature will be higher. One way to check the cooler performance, the cooling air temperature rise is usually 25degF.
Some compressors have package enclosures, aka canopies. If you restrict air flow through them, by placing a box or something over the inlet or outlet grating, you restrict cooling air flow.
Sounds to me like you have a room ventilation problem. I would also insulate your incoming air in the boiler room, make sure duct work is sized correctly, vent all cooling air exhausts outside and check your filters.
gr
