Which one of these coils would you choose for racing
Hi im im trying to builed an Ignition system for a drag car that is also street driven which one of these coils would be the better performer. Give resone for your answer.
Brand: Jacobs Electronics
Product Line: Jacobs Ultra-Lyzer Coil Kit
Part Type: Ignition Coils
Coil Wire Attachment: Male/HEI
Coil Style: E-core
Primary Resistance: 0.500 ohms
Coil Internal Construction: Epoxy
Maximum Voltage: 60,000 V
Turns Ratio: 85:1
Secondary Resistance: 2.6K ohms
Inductance: 5.2 mH
Peak Current: 250 mA
Spark Duration: 120 uS
Mounting Bracket Included: Yes
Coil Wire Included: No
Ballast Resistor Included: No
Coil Color: Blue
Coil Shape: Square
Height (in): 3.639 in.
Length (in): 4.289 in.
Width (in): 4.265 in.
Quantity: Sold individually.
Notes: Includes replacement coil wire boot.
Ignition Coil, Ultra Coil, E-Core, Square, Epoxy, 65,000 V, Blue, Each
Brand: MSD Ignition
Product Line: MSD Blaster HVC-2 Ignition Coils
Coil Style: U-core
Primary Resistance: 0.160 ohms
Maximum Voltage: 44,000 V
Turns Ratio: 100:1
Secondary Resistance: 630 ohms
Inductance: 3.5 mH
Peak Current: 450 mA
Spark Duration: 450 uS
Mounting Bracket Included: No
Coil Color: Blue
Coil Shape: Square
Height (in): 3.000 in.
Length (in): 6.000 in.
Width (in): 6.000 in.
Notes: For use with MSD 6 Series ignition controls.
Ignition Coil, Blaster HVC-2, E-Core, Square, Epoxy, Blue, 44,000 V, Each
Brand: Mallory
Product Line: Mallory Promaster Classic Series Coils
Maximum Voltage: 67,000 V
Turns Ratio: 129:1
Secondary Resistance: 12.5K ohms
Inductance: 4.8 mH
Peak Current: 120 mA
Coil Color: Black
Coil Shape: Square
Notes: This coil is for engines that operate between 4,000 and 10,000 rpm.
Ignition Coil, Promaster Classic Race, Square, Epoxy, Black, 67,000 V, Each
RE: Which one of these coils would you choose for racing
I would pick the one that was best suited to the type of ignition on the car, dwell control scheme(if applicable), RPM range, expected cylinder pressure, and mounting location. Even with all that information, in the end, I prefer to measure coil performance on vehicle, and see how it runs in real life before making any real decisions on it. Sometimes the problems with a cars ignition is inadequate voltage, sometimes its a spark duration problem, and that isn't always easy to predict.
None of those data points needed were listed here, so it'd be difficult to specify one coil as more likely to be properly suited for your application.
2 of your coils are 0.5 ohm primary, one is 0.16 ohm. They may not have the same intended application. There is a difference between coils designed for CDI, and coils designed for inductive(12V) ignitions.
Product Line: Jacobs FC 4000 Digital Fire Control Ignitions
Part Type: Ignition Boxes
Ignition Box Output: Capacitive discharge
Circuitry: Digital
Rev Limiter: Yes
Timing Retard: None
Data Acquisition: No
CD Voltage Output to Coil: 550 V
Current Draw: 12 amps at 10,000 rpm
Spark Output (millijoules): 302 Millijoules
Minimum Operating Voltage: 7.5 V
Maximum Operating Voltage: 16 V
Length (in): 8.500 in.
Height (in): 2.500 in.
Width (in): 4.500 in.
Ignition Box Color: Silver
Coil Included: No
CARB EO Number: D-19-34
Warranty: One year warranty
Notes: Prolonged street use will cause the ignition box to overheat. Recommended mainly for race use with minimal street usage.
Ignition Box, FC 4000 Fire Control, Analog, Capacitive Discharge, Universal, Magnetic Pickup Applications,Each
The MSD coil MIGHT fare better due to its primary resistance. I think of the ones listed, it is closer to ideal for a CDI coil.
As for making power, I'd suspect any of those coils should work OK with a CDI driving them.
Thankyou very much for your help.
Erdin
I have tried the others and had problems with them.
Crane fire wire plug wires are the best to use @25 OHM ft
Yes I took my car to the strip, 10.89 @135mph and drive it every day and hit the cruise's with not heat problems.
I run a full roller motor with a .585 cam for the street.
With a .690 lift cam it dynoed @ 679 hp
My toys I built or help build & race,
http://community.webshots.com/user/1bad80100
http://www
ht
Good looking and fast car you have.
Looks like you have the correct combination.
Try some Royal Purple oil products, and Marvel Myatery oil as an octane booster/ top end lube.
The oil helped my turbo Conquest quite a bit.
The gear lube took away the gear noise common in the rearend
of Vettes.
