Inserting a PdF
Inserting a PdF
I am trying to insert a portion of a Pdf file onto my drawing. All that I want to see is a portion of the Pdf.
I selected a portion of the Pdf and put it into model space. I then created a viewport. When I try to plot nothing shows up.
I believe that the problem is that I am using a black background for my drawing. The Pdf is black so nothing shows up.
I am running CAD 2005. Any help would be appreciated.
RE: Inserting a PdF
how did you insert a *.pdf...? As an OLE-Object?
Lothar
ADT 2004
RE: Inserting a PdF
RE: Inserting a PdF
David
RE: Inserting a PdF
RE: Inserting a PdF
From the ACAD screen: INSERT pull down menu> OLE object> INSERT OBJECT> from the Object type menu the Adobe Acrobatversion listed> from the OPEN dialog box find your file and open, the file is then automatically inserted in the ACAD drawing screen.
