Restricted Value Parameters
I'm having some trouble getting Pro/E to load the restricted value parameter definition file from the Config.pro specified directory.
The error that occurs specifies that the file is in the wrong format.  I'm not sure if it's the file format that is incorrect (as I cannot find one that works) or if the syntax within the file isn't being recognized.
Can anyone provide any insight?
