Matbro joy stick not working
We have a Matbro TR 200 M Reg and the joy stick stopped working suddenly. Al the buttons etc on the joy stick don’t work or the up and down tilt and crowd or the auxiliary all not working . The hydraulics work ok of manually operated with a spanner on the spool block . This lets us think the problem is electrical . We have checked the fuses etc. Can any one help me with this as what to try next.
RE: Matbro joy stick not working
- Check to see that you have electrical power at the joystick. There is probably an electrical connector close to the joystick that you can disconnect and check with a meter.
- Is there a hydraulic interlock function? (no hydraulics if the park brake is on, nobody in the seat, etc.) If so, maybe you have a bad relay. Or a bad seat switch. Most likely it would cut the power to the joystick.
- With good fuses and power at the joystick - then you probably have a bad ground. See if all the various coil grounds are connected together, and that this main ground lead has come off (or been cut or corroded) somewhere.
ISZ
JUST SPOTTED YOUR CONCERN ON THE MATBRO TR200!!
IF YOU NEED ANY HELP JUST EMAIL ME I SELL BOTHE NEW & USED PARTS FOR MATBRO MACHINES ETC...
REGARDING YOUR JOYSTICK IF THERE IS A FAULT IN IT YOU CAN CONVERT IT TO A TWO BUTTON ROLLER JOYSTICK TYPE!!
IT MIGHT EVEN BE THE SOLENOIDS ON THE VALVE BLOCK
THANKS
