Dual core processor usage with NX?
I'm still working with NX4 (currently waiting for the distributer for NX5) on core 2 duo intel processor and I've noticed that only one core is used by NX.
And I have a question - is NX5 optimised for dual coe processors?
RE: Dual core processor usage with NX?
You have to set an environment variable, either in the UGII_env.dat file or in your login profile.  The following is from the UGG_env.dat file:
#  MISCELLANEOUS
#  This variable enables Symmetric Multi-processing (SMP) on systems
#  with multiple CPU's or that support hyperthreading.  Performance will
#  be improved in certain Parasolid operations, such as Mass Properties,
#  Booleans and silhouette generation.  This option is only supported on
#  HP, SUN and Windows.
#     Set to 0 to disable SMP
#     Set to 1 to enable SMP
#     Unset will take the Parasolid default
UGII_SMP_ENABLE = 1
I hope this helps.
John R. Baker, P.E.
Product 'Evangelist'
UGS NX Product Line
SIEMENS
UGS PLM Software
Cypress, CA
http://www.siemens.com/ugs
Thanks for the help. I've checked and it was already set to 1. I don't know why task manager shows 50% usage of the processors. Maybe it's normal. I hope some people using C2D processors to tell if there is something abnormal in my machine or they also see 50% usage.
I suspect that unless you're actually performing one of the operations that leverages the dual-processor archtecture that you will not see any change in the utilization of the second processor.
John R. Baker, P.E.
UGS NX Product Line
SIEMENS
UGS PLM Software
Cypress, CA
I also have an Intel Duo 2 workstation however I've never run it with SMP enabled, but I thought I would test it.  I first took a model of a large and complex casting and created a COPY of the original solid body moved a short distance so that I could perform a Boolean test (one of the operations that leverage the dual-CPU archtecture).  I first tested it with SMP NOT enabled and the maximum CPU Usage that I got, as indicated by the 'Windows Task Manager' tool, was 50%, as I had expected.  I then enabled SMP and repeated the test only this time the CPU Usage went to a full 100%, again as I would expect it to.
So, at least with my configuration it works.
Note that I tested this with both UGS NX 4.0.4.2 and UGS NX 5.0.1.3 and got idenical results.
John R. Baker, P.E.
UGS NX Product Line
SIEMENS
UGS PLM Software
Cypress, CA
