Changing the object distance from the origin (API - COM)
Hi!
I'am a C++ programmer. I like to change the my object (in .SLDPRT file) distance from the origin (X, Z, Y coordinate) in my C++ (COM) program.
Which object and method do it? (Enough only the object/method name...)
Sorry a lamer question, but I'm lost in the SW object-tree... smile
Thanks!
ZsZs.
RE: Changing the object distance from the origin (API - COM)
To my knowledge there is not an easy way to move an arbitrarily designed part relative to its origin.  There are workarounds depending on why you want the origin in a different place.
Eric
I found a good example.
The after the SW API install, in the C:\Solidworks\api  directory (where is api help too) have a example by solidworks_api_session name.
It is very good...
