Subassembly dissapeared from drawing... Why?
Hello everyone!
I have a Drawing of an Assembly with 4 Subassemblies. Three of them are shown properly in the drawing but one of them just won't be shown.
The first time I made the drawing, everything was shown OK. After modifying a part and saving (not the subassembly with the problem, but another one) this one subassembly dissapeared.
I've cheked the original assembly and the subassemblies, I've opened all parts and saved them again and nothing. Still that one subassembly will no be shown. Does someone has a hint?
Have you had such a problem?
Cheers
Claudio
Cheers
Claudio
RE: Subassembly dissapeared from drawing... Why?
Have you checked the occurrence property of the sub-assembly in the assembly environment? Does it state "yes" at the "Drawing View" option?
Theodore,
Solid Edge V19 SP1 on WinXP SP2
Thank you very much.
I just don't know how this got deactivated... Is it normal that the parts and assemblies just dissapear?
Cheers!!!
Claudio
Theodore,
in the Help menu i just found: v17.
Claudio
this option seems to have a live of it's own. So it
might change it's state without manual intervention.
The other switch is 'Active Layer' within draft which
also has this behaviour from time to time and prevents
you from selecting items ...
Still the case with V19/SP3
dy
