Creep Coefficient
Creep Coefficient
For calculating the creep coefficient as per Eurocode2, I need the perimeter of the member in contact with the atmosphere(denoted by "u")
If the area of cross section of the member is "A".
Length of the member (member is a column)is "L", what should be the perimeter "u".Should it be "4 x L"
Please help!!
Please help!!
RE: Creep Coefficient
Sorry for the lengthy interrogation, LOL.
ho= (2Ac /u) , where, Ac is the cross sectional area of the member (the member is a column in my case) and "u" is the perimeter of the member in contact with the atmosphere.
The column is a composite column.
I want to know:
1)If the column is concrete encased I section, then, what will be the perimeter "u"?The concrete cross sectional area
may be taken as "Ac" as mentioned.Length of the column is "L"
2) If the member is a concrete filled circuar section,then what will be the perimeter "u"?The concrete cross sectional area
Please help!!
But now you say your column is a composite section. Are you sure the Eurocode2 provisions you are using apply to composite columns?
In case of concrete the code requires to modify "E" value in the expression.This "E" considering long term effects is also a function of creep coefficients
