End Cones for torsion springs
I'm currently working on finding a stronger and tougher end cone for torsion springs.  Presently my design is using the overhead door standard of a cast aluminum part.  These are about the best parts for the cost, but it seems they have a tendency to crack in our application.  Is there a stronger and/or tougher design on the market for winding a torsion spring?  More specifically I would need a part that fits a 2.0-in torsion spring and can work with loads as high as 55 to 60 ft-lbs torque.
If you have any leads please let me know.
Thank you,
Cooperjer
Mechanical Engineer
