Aircraft Type
Aircraft Type
Hello , I saw that someone named taylor mentioned that airplane F-15 uses JO-BOLTS fasteners. Can anybody confirm this information with actual documentation, or does anybody knows in what other aircrafts are used. Please advise.
Miguel.
Miguel.
RE: Aircraft Type
RE: Aircraft Type
Miguel.
RE: Aircraft Type
Jo-Bolts are in F-15 acft structural repair tech orders [T.O.s]... or at least they were when I was a field engineer working on them.
The flush-shear head Visulock II Titaniun 5/32-Dia X 0.125"-grip JB you specified is loaded under NSN 5320-01-279-3379 in IHS Haystack. It is NOT delegated to any aircraft series.
There MIGHT be an application for the PLT5471 [1/64" OS]...however, the size noted [5/32"-Nominal Dia] appears to be "too small" relative to most JBs that might be used on the -15... although it could possibley used for field fastening... thru thin structure.
Regards, Wil Taylor
